The High speed Rolling Circle
Discussion in 'How To- 3D Flying and Aerobatics Flying' started by Tomcats3DRC, May 17, 2015.
  1. Tomcats3DRC
    Tomcats3DRC 30cc
    16
    0
    1
    The rolling circle is a classic sport flying maneuver that everyone would recognize. The high speed rolling circle brings this maneuver to the next level. When in the maneuver the plane is always at full throttle, which is what makes this maneuver so hard. Your roll rate is so fast, but to keep it level, you have to coordinate the rudder and elevator. When the plane's top faces the sky, you have to give up elevator. When it's on it's side, you have to give rudder. When the plane is inverted, you have to give down elevator. Finally, when the plane is on it's side again, you have to give rudder. These quick movements on the control surface are very small but if you don't get your coordination right, you go straight into the ground. The plane's roll rate is so fast that you have to make these adjustments in a split second. Here's a video of Jase Dussia doing high speed rolling circles at 2:06:
    https://www.youtube.com/watch?v=ighi9eHFqFA
    If this doesn't work, you can also find it on youtube under "2014 XFC Jase Dussia Sunday Final Freestyle HPP"
  2. Jase sure is fun to watch!
  3. Bloosee
    Bloosee 70cc twin V2
    Jase is just absolutely ridiculous. Those rifle rolls he does should not be humanly possible, and to do it while steering the plane around!
  4. SnowDog
    SnowDog Moderator
    3,063
    18
    38
    yeah - that's some crazy stuff...that crankshaft was sick as well....and the knife edge spin was at such high speed I thought he was going to rip the tail off the plane!
