Set-up of EP 72 inch extra
I would like to know how you would set-up the 3dhs 72 in extra?
There are many options available, and they're all great.
If going electric, definitely get Motrolfly motor, they are the best.
My 72" is setup with a DLE 30 and Savöx SA-1258tg servos.
If you have a specific question, please ask!
Do you set it up with batteries to run servos only, or set it up like a smaller electric. I haven't decided 74 edge or 72 extra. What's the best way?
Thanks for the welcome, RC has had a big impact on me. Probably kept me from going crazy. Was blown up in Afghanistan 2009, and in wheel chair now.
Thanks for your service and sacrifice from a fellow vet. I'm currently AD USAF :)
Yes, I have a 2800mah Li-Ion in mine that is good for 3x 20 minute flights.
I've had both the 74" Edge and the 72" Extra, and I prefer the Extra. Whatever you do, reinforce the wings if you buy an extra. They are too weak for aggressive tumbles and spins.
As for "the best way" I suppose one big question is do you have batteries for an electric motor already, such as a 6s5000 or two 4s4000? If so, an electric setup may cost you similarly to a gas engine. If not, a gas setup will be less expansive and give you longer flight times.
-G
wow...sorry to hear that...I guess your screen name says it all.
I know this sounds cliche sometimes, but I mean it: thank you for your service and your sacrifice.
I'm glad for you that R/C has had such a positive impact on you!
so getting back to the plane....
3DHS 72" Extra - there is one choice that will drive many other decisions: gas or electric? I'm gonna guess you want electric since propping a gas motor from a wheelchair is not really practical. 3DHS has a good web page that talks about the gas and electric setup options for this plane, and their recommendations are very appropriate and have met with great success.
http://www.3dhobbyshop.com/72-Extra-330SC--Red_p_15148.html
http://www.3dhobbyshop.com/72-Extra-330SC--Yellow_p_15149.html
Red or Yellow, the assembly is the same ;)
Online pdf manual here: http://www.3dhobbyshop.com/assets/images/3DH-72EXTRA/3DH-72EXTRA-Manual.pdf
Motor: 3DHS recommends the Hacker motor with a Castle ESC and a BEC.
The 74" Edge is setup in a similar way with similar equipment. I think one of your earlier questions was do you connect everything like the smaller electrics?
I think you are asking about the motor/ESC/BEC combination so that is what I will describe.
For a plane this size, the battery is usually connected to the ESC with a built-in BEC, or the battery is connected to a standalone ESC (OPTO) and also a BEC.
Some people even use a separate battery for the motor and the receiver/servos, in which case you do not need a separate BEC.
I'm gonna stop there and let you respond to help guide the conversation without info overload.
There are threads on the 72" Extra and the 74" Edge already chock-full of good info:
http://www.3drcforums.com/showthread.php?203-72-quot-Extra-330SC
http://www.3drcforums.com/showthread.php?94-74-quot-Edge-540
Post more questions here once you've had a chance to digest some of this info. :)
yea I'm going electric, I guess what i'm saying is how to set this plane up for electric. I already have a CC edge 100 and a60-7s, do I need CC bec pro? probably will use 7955tg on surfaces.
cardenflyer
I don't think we can thank you enough for what you did.
As far as set up, those.servos will be crazy good for that size. And yes run a separate battery from your motor power. I'm not sure which plane is better. I'd guy with whatever one you like the looks of better.
Thanks. I need to see someones setup to figure this out I guess. I know how to set up an electric with motor, esc, and batteries, Just unsure of how to do it an have a battery for just run servos.
