Tony, thx for the 1/8" recommendation. Perfect size. And flex.
TonyHallo
Here's a spare bungee for my Super Cub, 36" long 1/8" cord. To make the loop, put a 1/4 drill bit in a vice, loop the end over and stretch both the free end and cord with a pair of pliers or vice grips, then tie the stretched section with fishing line, I use a Kevlar line, after a number of wraps saturate the area with thin CA. I no longer make loops on each end rather just make larger loop 18" long, only need on connection. I don't believe you will have room for the crimps. I guessing your plane will come in about the same, 39 pounds with scale details, fabric and painted. I don't remember the recommended length from BUSA but I'm sure I'm almost double that. My gear does not deflected when the plane is at rest.
