TonyHallo
I really do like the bungees on the Super Cub, they offer shock absorbing rather than the bounce you get with springs. Using about 36” of 1/8” shock cord for mine for each side
I need end caps on my landing gear pins. Thinking soldering washers on the ends but my Flux is dried out....
TonyHallo
Too fancy! I use tap water. I keep my flux in a glass jar with a sealing lid and still need to add water from time to time.
TonyHallo
I use the Harris black flux, I think it is easier to clean off. To clean the majority I quench in water, then reheat and quench to pop the flux off. As you reheat you can see the flux turn from glass to crystal, then quench.
1/8" bungee is obviously much better sized for this application than 3/16". Although side by side they don't look a 1/16 different. I bought some bungee crimps but not sure they are the right thing.
