For Sale High capacity Switch w/Voltmeter Display
Rich G
High capacity receiver switches (single and doubles) with a built in volt meter display! Now you can always see what voltage you are at even under load. Both have 20AWG wires and the single is rated at 20A and the double is rated at 2 X 15A. The double is indeed 2 separate switches and the voltmeter will bounce back and forth and show the 2 different voltages (assuming both are turned on) and can run different voltages if you desire.
Check them out at http://www.purpleplugpuller.com/switches.html
$22/single $30/double plus $4 flat shipping.
