First Question?!?!
G.P.
Howdy Joe!
So how do you do the "Chuckle"? I have only gotten out flying twice this summer, so I haven't figured it out yet. I would like to try it next time I get out there though.
Thanks!!!
Greg
So Joe, what pills do i take to be able to fly like you? :)
When inverted harrier, do you use any trick to remember the rudder direction input, besides practice?
quadracer
Howdy Joe!
Thanks!!!
Greg
I've been wanting to learn the chuckle as well, but I don't think my 57 SC has the inertia to pull it off. Maybe I'm just not skilled enough yet...
scarface
II do that on the sim all the time, I just can't remember my stick movements and my dad will have my sim for a couple of weeks. It is like a pop top but you don't go fully vertical.
Howdy Joe!
Thanks!!!
Greg
A chuckle is basically a normal tumble starting from inverted and then switching the aileron direction. A normal tumble would start from inverted, the right gimbal would go to the top right corner, and the left gimbal would go to the bottom left at the same time. A second after you do those inputs, switch to full left aileron and it should flatten the plane out and cause it to end upright, facing in the opposite direction.
There were two things I used to remember rudder inputs for inverted harriers. First, when the plane is coming towards you, push the stick the way you want the nose to go. Second, when the plane is going away from you, push the stick the way you want the tail to go.
Btw, I actually do take B12 before I fly. :D
3dNater
Watch out Joe... they are going to start testing for vitamins in all the competitions now :D
