3D vectored Rafale with G-FORCE Smoke-EL (UltraHD/4K)
dominicm
Superb demonstration of this giant scale Rafale from Aviation Jets. This monster sized jet is powered by a Kingtech K310 jet turbine engine. Has 6 high torque Mks servers routed into a Powerbox system complimented by a Gyro Bavarian Demon Cortex for stability.
This Smoke-EL device’s GF-SmokeDriver is equipped with a 3-axis MEMS sensor which measures the force perpendicular to the plane’s wing. The G-Force that acts on the Jet in tight curves or loopings will automatically activate the smoke device and in turn deactivate it once the force is no longer active. Thus you can imitate a real jet’s wake turbulence. The force that is necessary to activate the smoke device is configurable but was 4G on this flight. The sensor can be adjusted from 2 – 7g (1g is the acceleration through the earth’s gravitation at the earth’s surface. 1g = 9.81m/s).
Cant even begin to tell you how jealous you have just made me!
The very jet I want with a beautiful paint scheme and the smoke system is out of this world!
No place to go from here, you have gone to the end of the road!
Richard
