150cc Extra canister install
jj46
Has anyone put a DLE-170 with canisters in the PAU 150cc Extra? The DLE headers are a 70mm drop I believe. A DA install requires 90mm drop, but not sure if the cylinder spacing is the same.
jj46
Just as a follow-up to this thread, the DLE-170 flex headers that come in the canister setup work fine on this plane.
jj46
jj46
mndless said
Nice ! How are you venting along the bottom ?
Nothing special, I just cut the bottom of the cowl as shown in the manual... basically a fairly large half-circle opening at the very bottom of the cowl.  For the outlets, I simply opened up the pre-cut holes.  I didn't do any other venting, I think enough air is flowing through the tunnel to keep things cool.  I did use thin light ply to close up the can tunnel to cut down the heat in the fuse.
Wasn't done wiring in these pics but you can see the sheeting.
