SAB Avio KR84 Tortuga - Freaky Fast
dominicm
"IT's TORTUGA TIME !" That's what we heard as our Italian friends from SAB Avio bungee and hand launched their Tortugas into the air to give a hot demonstration of the speed of the new Tortuga from SAB Avio.
TORTUGA is a Full sandwich Fiber glass / Airex Fuselage (made under vacuum).
- Super rigid, ready for High speed.
- All parts are already painted.
- Horns are already mounted.
- Super-fast assembly, in 2 hours the model is ready to fly.
Specification:
Wingspan: 84 cm
Length: 81 cm
Weight RTF: 1.55 KG
Wing area: 2400 cm2
Recommended setup:
Channels: 4
2 x mini wing servos 30 x 10 x 30 mm
1 x micro servo 12 x 23 mm
Flight battery: 6S — 2600 / 3200 mAh
Motor: 2200 kV, 28-36mm
ESC: 100-120A-ESC,
Propellor: 5x5
Max motor size: 36mm diameter
Max motor weight: 150 grams
Battery Compartment: 55x45x200 mm
