Peak Models 32% Extra 330 SC
Got the throttle servo attached to the carb and throttle settings programmed.
Will work on the ignition next. Looking forward to getting the first tank ran through the engine :) Should be very quiet at idle with the air filter system and canister.
Just had to put the cowl on with the prop and spinner. Still trying to get used to this scheme :trance:. Cowl opening is rough cut for now but seems it is going to cool well. Will need to make draft openings on the bottom of the fuse kinda like an electric.
Just stumbled onto this one so this is we’re all you guys are hiding had to read 67 pages to catch up. So this is were all the good stuff is discussed. Like the carbon fibre rudder tray.
Shhhh.....be very quite. This was supposed to be a secret. Kelly didn't want anyone to know that he was actually building a man's plane. You know, as in gas?! You know how those electrified Nitro dudes are.
