Mila203
Na tomto letadle používám Saito FG2. A na přední straně je velká váha. Dali jste také závaží na zadní část výtahu?
Mila203
I use a Saito FG21 on this plane. And there's a lot of weight on the front. Did you also put weights on the back of the elevator?
I don’t recall adding any weights to the tail. Make sure you have the current manual for CG. The original had a addendum, as it was too far aft. Cubs have a pretty wide CG range. You should be fine without adding any weights, but check the CG.
Exactly. I had an old manual where it was 151mm .. The new manual is 120mm .. Thank you
Glad I mentioned it! I first trusted the manual instead of my gut (this was before the addendum came out) and it was so incredibly tail heavy I almost lost the plane. extremely pitch sensitive. Have fun!
HI AKNic...just getting really into nearly giant size...I am collecting CUBs...large ones..all second hand...but i am getting some good info from your shots....what addition is the MAN and year...so i will post soon some shots of mine...1st CUB is 2.2 mteres...the 2nd is 2.9 mtres and I am delving into uncharted territory...so thanks again for you pics...Bill N..PS whilst its tougher in ALASKA its Bloody Hard in Australia.
We do love pictures! I'm not sure I follow what you are asking? This is a thread specifically for the Hangar 9 15cc Carbon Cub. MAN & Year? Not sure what you mean? Thanks!
mr bigpitts
Has anyone installed or aware of the little saito 19 radial being used in this aircraft?
I'm aware the jugs would protrude from the cowling (which I think would look cool) and I have heard one running at my local field and have fallen in love with the sound.
Comments and thoughts would be appreciated, just interested in scale performance
